VAFC... What is VTEC Unmatch Fuel Correction ?
Old Apr 11, 2004 | 10:55 AM
X2BOARD's Avatar
Default VAFC... What is VTEC Unmatch Fuel Correction ?
I've read the pages over and over.... can't figure out exactly what it is...
Can any experienced AFC users/tuners explain it to me, please ?
Old Apr 11, 2004 | 11:47 AM
IN VTEC's Avatar
Default Re: VAFC... What is VTEC Unmatch Fuel Correction ? (X2BOARD)
It adjusts the amount of MAP voltage (fuel) in b/w the Vti and Vto to take away or add fuel in that region b/w where stock VTEC engagement (Vti) and VAFC applied engagement rpm (Vto).
Whether you use Lo -> Hi unmatch adjustment or Hi -> Lo unmatch adjustment depends on whether the Vti is higher or lower than the Vto. See manual for which one you should use for your situation.
Old Apr 12, 2004 | 04:15 PM
X2BOARD's Avatar
Default Re: VAFC... What is VTEC Unmatch Fuel Correction ? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">See manual for which one you should use for your situation.</TD></TR></TABLE>
I don't quite see where it tells me where to do it ? What if I have the VTi and Vto being the same (stock engagement) should i assume no changes ?
Also it's in a percentage....how do i calculate the figure I would need ?
Old Apr 12, 2004 | 04:28 PM
turboxsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">
Also it's in a percentage....how do i calculate the figure I would need ?</TD></TR></TABLE>
I wanna know too!!!
Old Apr 12, 2004 | 05:36 PM
IN VTEC's Avatar
If the VAFC is set to the stock engagement, the VTi = VTo, so any changes you make wouldn't have any effect. But, in such a case, no changes need to be made.
The changes to the unmount correction would have to be done so that you can measure its its effects....like on a dyno.
I've never had a chance to doing any testing with the VAFC fuel correction, so I don't know how much each percentage point is in AFR points. It's probably pretty linear tho unless the basemaps have odd VE hills/humps or valleys.
Old Apr 12, 2004 | 08:34 PM
X2BOARD's Avatar
The more I read...the less I feel I know...
Old Apr 13, 2004 | 10:08 AM
X2BOARD's Avatar
bump for any more info.
Old Apr 13, 2004 | 12:27 PM
turbodGSR's Avatar
in a more simply way of saying it is if ur vtec is higher then stock inbetweem ur old vtec and new vtec point will be rich since or still running on low cam fueling. If u lower ur vtec it u will be running in high cam on low cam fueling. if u raise ur vtec ur will be running low cam on part of ur high cam fueling.
Old Apr 13, 2004 | 01:24 PM
X2BOARD's Avatar
Default Re: VAFC... What is VTEC Unmatch Fuel Correction ? (turbodGSR)
That's kinda what I figured... but how does this work as a percentage (The vtec unmatched correction figure is a percentage) ?
Old Apr 13, 2004 | 04:02 PM
tencan's Avatar
Bump for some knowkledge
Old Apr 14, 2004 | 05:33 AM
X2BOARD's Avatar
Default Re: VAFC... What is VTEC Unmatch Fuel Correction ? (tencan)
morning bump... must learn more !
Old Mar 20, 2006 | 07:55 PM
Coupe-R's Avatar
The correction result is as follows:
Air correction factor(*1)=correction factor based on engine RPM and throttle opening (*2)+Unmatch correction factor
H&lt;&lt;L=the VAFC II is at Hi cam (ON), but the ECU only reads Lo cam (Off). use this setting if u lower the stock vtec point.
with the percentage Im going to guess that the car needs 25% more fuel here, so ill try that. otherwise u need a wideband 02 or dyno
98 blacksh
Feb 17, 2005 02:23 PM
honda8882
Jul 23, 2003 11:27 AM
Pompiuses
Jul 9, 2003 01:40 AM
fxrob
Jun 12, 2003 08:59 PM
eddiecut
Sep 30, 2002 07:44 PM
