USDM Type-R Head on a USDM GSR Block?
Old Sep 21, 2001 | 08:56 PM
slowcivic's Avatar
New User
Default USDM Type-R Head on a USDM GSR Block?
What would be the advantages of doing this? Would I gain any compression? How hard would it be to install? T.I.A.
Old Sep 21, 2001 | 11:22 PM
Slain's Avatar
Default Re: USDM Type-R Head on a USDM GSR Block? (slowcivic)
all i know is that it will bolt right on . and it will have a lower compression than a full type r motor due to the gsr's pistons
Old Sep 21, 2001 | 11:38 PM
nugget8000's Avatar
New User
Default Re: USDM Type-R Head on a USDM GSR Block? (Slain)
I have also heard that you loose something like .3 in compression, can't remember exacly why, something to do with the shape of the combustion chamber or something. I have definitely heard that you would loose compression though. Advantages would be: better cams, lighter and larger valves, stiffer valve springs, and light headwork.
Old Sep 22, 2001 | 12:42 AM
Shoe's Avatar
New User
Default Re: USDM Type-R Head on a USDM GSR Block? (nugget8000)
The GSR head has a bigger combustion chamber and therefore will end up with a lower compression ratio.
Old Sep 22, 2001 | 05:22 AM
slowcivic's Avatar
New User
Default Re: USDM Type-R Head on a USDM GSR Block? (Shoe)
Ok, thanks everyone! I appreciate the input!
Old Sep 22, 2001 | 06:01 AM
rainforest's Avatar
no its the other way around the gsr has a smaller cumbustion chamber.
Old Sep 22, 2001 | 07:24 AM
Blown90hatcH's Avatar
Default Re: USDM Type-R Head on a USDM GSR Block? (rainforest)
Correct...the gsr has a smaller combustion chamber. That is why when you put the Type-R head on it will drop the compression by around .3. The type-r has a bigger quench area.
Old Sep 22, 2001 | 03:02 PM
SpoonCivic's Avatar
New User
Default Re: USDM Type-R Head on a USDM GSR Block? (Blown90hatcH)
ya ull have to get a new set of pistons cuz compression will drop to 9.5 from the 10.1:1 cr the GSR pistons have on the GSR head.
bustdgst
Jan 26, 2007 01:05 AM
BMo Tuning
Aug 17, 2006 03:41 PM
slowcivic
Sep 21, 2001 09:00 PM
