USDM ITR swap into 92 VX
Old Oct 24, 2003 | 10:41 AM
MGD's Avatar
MGD
Default USDM ITR swap into 92 VX
First things first, i did a search.....but couldn't find exactly what i was looking for.
My question is this, Since my car is a VX...Is there going to be any problem with wiring because of the VX's 5 wire O2 sensor.....Do i have to repin the chassis harness.....
I'm going to use the obd-2 harness and p-28 ecu....if that helps
any other wiring info would be appreciated......Thanks
Old Oct 25, 2003 | 04:52 AM
MGD's Avatar
MGD
Default Re: USDM ITR swap into 92 VX (MGD)
Can't anybody give me some insight on this topic!!!
Old Oct 25, 2003 | 07:24 AM
JDMHN8's Avatar
Search for post by or PM VTECvillan for some help with the VX wiring. This guy knows his **** about everything involving wire. Helped me tremendoulsy. You may have some additional issues since it's OBD II into OBD I.
You do have to fiddle with the O2 sensor, but it really is easy. If you have any questions about which OEM mounts to use, I can help you out there.
Old Oct 25, 2003 | 10:44 AM
Nerv2g's Avatar
Default Re: USDM ITR swap into 92 VX (JDMDA9)
here is the link man, with pics!!
https://honda-tech.com/zerothread?id=635782
Old Oct 26, 2003 | 05:30 AM
MGD's Avatar
MGD
Default Re: USDM ITR swap into 92 VX (Nerv2g)
Thanks for the help!!!!!!
Old Oct 26, 2003 | 09:31 AM
Nerv2g's Avatar
No probelm
badboyr66
15
Oct 14, 2007 04:40 PM
badboyr66
Oct 14, 2007 09:11 AM
The Alchemist...
Jul 13, 2005 12:20 AM
todbld
Jan 10, 2005 03:12 PM
backdraft
Apr 7, 2004 11:25 AM
