Under-Drive Pulleys -Are NOT GOOD For High-Performance Driver- says this article!
Old Feb 12, 2004 | 10:44 PM
tzenisj's Avatar
Default .
Modified by eric.ws.anderson at 11:55 AM 10/3/2008
Old Feb 12, 2004 | 11:38 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Under-Drive Pulleys -Are NOT GOOD For High-Performance Driver- says this article! (civic_rice)
water pumps on Honda motors are driven by the timing belt, not a utility belt.
besides, high-performance Chevy is 4500-5000 RPMs redline. at 9-10K RPMs water pump will caveatte the water around the impeller.
Anyway, moot point, does not apply in this case.
under-driven alternator is a good idea, since over-spinning them tends to blow the diode arrays out.
Stan
Old Feb 13, 2004 | 12:24 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Under-Drive Pulleys -Are NOT GOOD For High-Performance Driver- says this article! (Stan D)
If you run something like the AEM pulleys you'll be ok since they keep it off of the crank. Now the crank pullyes are a bad idea!
Old Feb 13, 2004 | 03:47 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D &raquo;</TD></TR><TR><TD CLASS="quote">water pumps on Honda motors are driven by the timing belt, not a utility belt.
Not all of them, older ones ran off the alternator belt.
Old Feb 13, 2004 | 07:22 AM
Default Re: Under-Drive Pulleys -Are NOT GOOD For High-Performance Driver- says this article! (Chiovn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Not all of them, older ones ran off the alternator belt. </TD></TR></TABLE>
i was referring to the D, B and H series.
Stan
GsR92HaTcH
Sep 30, 2007 09:21 PM
zracer240
Aug 1, 2005 10:07 AM
gsrboi80
Aug 18, 2004 10:36 PM
turrismaldon
Oct 29, 2002 07:33 AM
