Turn Signals not working?!
Recently my turn signals stopped working it happened when I blew a fuse... I replaced the fuse and they still don't work, my back up lights work (on the same fuse) and my hazards work.... any ideas??
thanx
thanx
i checked the fuses under the hood and the main fuse box under my dash, like i said my hazards still work fine so i know all the bulbs are fine, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">what about the back up fuse, and interior fuse, checked those yet? i had a similar situation happen to me once, no tail lights and no signals, was not a funny thing</TD></TR></TABLE> back up fuse located where? ....i know what u mean i found out after i drove home from work ( at 12:30 in the morning) that i had no tail lights on the way home, but i replaced the fuse and everything works except for the turn signals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DOHCGsr »</TD></TR><TR><TD CLASS="quote">it could also very well be your flasher. Pick one up at any auto parts store for like 20 bucks. Hope this helps</TD></TR></TABLE> flasher?? are you talking about the physical switch on the colum because my headlights are on the same switch ( i turn the dial for headlights pull back for brights and up and down for turn signal) because my headlights and the bright light function still work
If you want to check the turn signal switch is working here's how to:
remove the upper and lower steering wheel cover. Bottom cover is held in by 3 screws. Upper cover is snapped in to the bottom cover. now remove the two screws that is holding the switch in place. Unplug the 4-pin connector and a 7-pin connector going to it. check the continuity between the three pins on the 4-pin connector.
Kellybaraka
Feb 11, 2016 08:55 PM
Mishima
Jun 30, 2009 09:08 PM
GSlowR
12
Oct 5, 2002 07:14 PM
