Tuning questions with Crome/Uberdata/BRE
I just downloaded BRE2.0, and am thinking of downloading Uberdata for my bro's car. His ECU is already chipped. I am planning on Supercharging my car, and the closest tuner with a fwd dyno is about 10 hrs away, and I want to mildly street tune my car before I drive to the dyno (so my car will make it)... yeah, I'm in BFE, but dont have anywhere to install the SC when i get to a place with a dyno. But basically I've been on PGMFI.org, and looking and looking. Now when I open a new .bin file up (JdmPr3Boost11-12.bin) and look under fuel map 1, I am assuming that the column on the far left is the RPM of the engine. I have no clue what the colored numbers represent, or what the top row represents either. Now let me remind you, i have been searching. Could someone explain to me what these are, and the same in ignition map?
I am also assuming (because I am extremely new at this) that fuel map 2, and ignition map 2, are for v-tec crossover? I could be wrong, but I'm trying to figure it all out. Even the newbie stuff on PGMFI has my eyes going crossed.
I understand the tag that says JDM Pr3 dev parameters... kind of self explanatory, and I get the dev options tag also, except once again I am confused as to what the numbers on the bottom mean (obviously where it says map sensor, its for which map sensor you are running).
Any and all info would be greatly appreciated... I'm gonna ask on PGMFI too, I was just here when I thought to ask for help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectLSVTEG »</TD></TR><TR><TD CLASS="quote">I am assuming that the column on the far left is the RPM of the engine. </TD></TR></TABLE>
You are right!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectLSVTEGI have no clue what the colored numbers represent [/QUOTE »</TD></TR><TR><TD CLASS="quote">
Those are the values for the fuel being injected, don't really correspond to anything that I know of, but the ECU does.
[QUOTE=ProjectLSVTEG]or what the top row represents either</TD></TR></TABLE>
Load variables. Vacuum on the left, boost on the right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectLSVTEG »</TD></TR><TR><TD CLASS="quote">I am also assuming (because I am extremely new at this) that fuel map 2, and ignition map 2, are for v-tec crossover? </TD></TR></TABLE>
That's correct also.
Good luck,
PS: Crome is better than Uberdata
You are right!
Good luck,
well, irhgt now i am playing with BRE. but am thinking about d/ling crome. I am very new to this, but need to get it down, cuz once the car is SC'ed, i am gonna put it on a dyno... but like i said, i have to do it here, and drive close to 10 hrs.
schuessler28
12
Aug 2, 2005 07:35 PM
