TruFilters... Total BS or Something Worthy?
Old Jun 12, 2005 | 06:30 AM
MugenGTR's Avatar
Default TruFilters... Total BS or Something Worthy?
This product is originally targeted at the offroad market but it does makes applications for Hondas as well. It sounds kindda nice, but thing again, every ad out there sounds nice...
Good for the life of your motor. Lifetime Warranty.
Superior filtration means less wear on engine or fuel systems, providing extended life of equipment.
Eliminate filter inventory.
Eliminate cost of filter disposal.
Extended oil change intervals from 3000 miles to 7000 miles.
Saves money, time and the environment.
PERFORMANCE BENEFITS
MOST EFFICIENT FILTRATION- Computer tested and race proven to be over 90% more efficient in removing 35 micron and smaller particles. (Most harmful to engines) than paper filters.
LARGEST FILTERING AREA- Deep pleated, duplex woven, 45 micron, T304 stainless steel filter media has the largest amount of filter area available and provides for ABSOLUTE filtering. Cleaner oil equals longer engine life, longer oil life,
MAXIMUM FLOW VOLUME- Our quad flow technology doubles the filtered oil flow allowing you motor to run more efficient.
REUSABLE & CLEANABLE-Reuse over and over. Cleaning can be done with soap and water or in a solvent parts washer.
EASY INSTALLATION-no special tools needed. Simple spin-on replacement. Best fit and Viton (r) seals to prevent LEAKS! Convenient finger grips for a TRU grip.
REMOVABLE INSPECTION CANISTER- easy spin off outer cup to allow inspection & cleaning-anytime.
SUPERIOR QUALITY & WORKMANSHIP- 6061 T6 billet aluminum housing is designed, engineered and manufactured to last for life.
O RINGS- Viton ®, lifetime seals, the ultimate in durable sealing ability.
ENVIRONMENTAL BENEFITS:
Eliminates used paper filters from the waste stream.
Lifetime filter systems, through superior filtration, extend oil drain intervals from 3000 miles to 7000 miles thereby reducing the used oil and filters sent into the waste system.
Helps protect our environment!
Old Jun 12, 2005 | 12:19 PM
Lord Helmet's Avatar
Default Re: TruFilters... Total BS or Something Worthy? (MugenGTR)
I've seen those filters before with Wix and Canton(I believe). It has the same philosophy as K&N air filters. Reusable filters are good if you clean them like the way the manufacturer wants you to do it. BTW what is the cost?
Old Jun 12, 2005 | 02:33 PM
Kendall's Avatar
At the very least I think they're worth a shot. I still wouldn't go more than 3k miles between changes though.
Old Jun 12, 2005 | 02:48 PM
slomofo's Avatar
GDD Member
Dude, a shiny aluminum oil filter! Where do I sign up?
Old Jun 13, 2005 | 06:19 AM
EE_Chris's Avatar
Default Re: (slomofo)
Canton
What's the cost of TruFilter setup?
Old Jun 13, 2005 | 06:50 AM
IN VTEC's Avatar
Default Re: (EE_Chris)
The Trufilter is $142.00 from Hop Up Racing or whatever it's called, I don't remember exactly.
The Canton Racing cartridge filters aren't reusable as far as I know and they also don't have a bypass valve. I'm not sure if the Trufilter has one either.
I'm going with the Canton Racing filter. You can only use a 4" tall spin-on cartridge unless you have a remote-mounted oil filter.
piggydog
Jun 21, 2007 01:58 PM
AnAccordIsForever
Nov 13, 2005 07:11 AM
Tweakmeister
Feb 1, 2003 09:19 AM
Cyrio
Mar 18, 2002 08:10 AM
