Transmission locator pins
Old Nov 26, 2007 | 04:18 PM
EFsideways's Avatar
Default Transmission locator pins
Alright, over the thanksgiving break from work i put in my zc.I could not get the usdm si tranny dowl pins to line up with the jdm block...i was struggling doing it alone.So,,I just got i the bolts lined up and tighted away.All seems well,but i know they were engineered in there for a reason.I guess i have two questions..1. Can i get away with what i did,or is it out of alignment? "just lined up the bolts an installed it" -or- 2. Does honda make a shoulder bolt i could use to align my tranny ,if it is out of alignment.Anything would help
Old Nov 26, 2007 | 07:54 PM
Hybrid96EK's Avatar
Default Re: Transmission locator pins (EFsideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFsideways &raquo;</TD></TR><TR><TD CLASS="quote">Alright, over the thanksgiving break from work i put in my zc.I could not get the usdm si tranny dowl pins to line up with the jdm block...i was struggling doing it alone.So,,I just got i the bolts lined up and tighted away.All seems well,but i know they were engineered in there for a reason.I guess i have two questions..1. Can i get away with what i did,or is it out of alignment? "just lined up the bolts an installed it" -or- 2. Does honda make a shoulder bolt i could use to align my tranny ,if it is out of alignment.Anything would help</TD></TR></TABLE>
I can't see any reason why leaving out the dowel pins would cause any kind of issues. They are there mainly to assist with mating the engine and tranny together. More of a locator pin then anything. So long as all the bolt holes lined up correctly you shouldn't have any issues at all.
Old Nov 28, 2007 | 03:13 PM
Jago's Avatar
Default Re: Transmission locator pins (Hybrid96EK)
leaving out the dowels can cause the bellhousing to crack.
Old Nov 28, 2007 | 03:43 PM
Hybrid96EK's Avatar
Default Re: Transmission locator pins (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">leaving out the dowels can cause the bellhousing to crack.</TD></TR></TABLE>
Really? How so? They have something to do with vibration dampning?
Old Nov 28, 2007 | 04:03 PM
EFsideways's Avatar
I think they are there for alignment than anything else.I run a cnc mill and had to re-align it due to a rookie crashing it.It had very similar pins in the pallet for alignment.But im not sure thats why i asked.
Old Nov 28, 2007 | 07:08 PM
Jago's Avatar
the dowls are there to not only line up the trans to the engine but also to keep the
transmition from twisting on the the engine. Without the dowls the transmition will be able to twist forward and back on the engine a small amount when under load.
This can over time cause the bell housing to crack.
Old Dec 1, 2007 | 03:50 PM
EFsideways's Avatar
I don't know why they didn't line up, prolly cause i was by myself and am blind.Should i just try to put them in, grin and bear the labor?It's built more for reliability than drag racing.Should i really be worried about it?
D16SohcVtec
Feb 16, 2008 02:00 PM
VTECcnIT
Jan 29, 2006 11:47 AM
Ej1_coupe
May 17, 2005 08:37 PM
coot_er
Oct 8, 2004 08:54 AM
Unjockable
20
Nov 10, 2003 02:36 PM
