Transmission help/question.
Well I got a transmission from a junkyard for $20. Not that it really matters but the car had 140k on it. The shift linkage was already taken so i wasnt able mess with the gears.
My question...is there any way with out actually putting the tranny in and testing it to know if it is any good? I realize its easy to install a tranny but my buddy wants to buy it if its anygood. I even told him he can install it and if it any good to buy it, if not than take it back out. But he doenst want to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">you could maybe use x-ray vision to look through the case
I think I found a pair in a cereal box with I was 8, haven't seen them since. Sorry Bro.</TD></TR></TABLE>
I have x-ray so that wont be a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VX_EG »</TD></TR><TR><TD CLASS="quote">You can pull the case apart and inspect the internals of the tranny. That's the only way to check it out unless you put it in a car.</TD></TR></TABLE>
Well im going to take the case apart because I want to learn a little about transmissions. What do I look for? Broken teeth, metal shavings?...
sanjiyan69
Jul 9, 2004 07:29 PM
