Tranny ?'s
Old Oct 15, 2003 | 09:41 PM
sloweredcivic's Avatar
Default Tranny ?'s
I fried the differential in my transmission a few days ago in my 90 hatch. So i now have my four speed spare tranny in the car. I have a zc tranny with a broken housing my dx tranny with fried differential, and a 95 delsol tranny. so my qusetion is will all of the gears interchange? I would like to take the diff form the zc and the first four gears and possibly depending on the ratio of the fifth out of the delsol tranny. If the zc diff won't work can i use the delsol diff. any help or ideas would be great thanks
Old Oct 15, 2003 | 09:56 PM
keithg's Avatar
Default Re: Tranny ?'s (sloweredcivic)
I am fairly certain that the diff from the zc trans and del sol trans is not compatible with the 88-91 inner cv joints. If your trans with the fried diff is a 88-91 dx/lx or is a 90-91 si trans, then the diff from a 88-91 four speed trans should work. (the 88-89 si has a unique diff.) You should be able to use the zc gears. I am not shure about the del sol fifth gear. If your blown diff trans is an si, you will probably want to use that final drive.
smokez187
May 13, 2007 12:17 PM
See Are X
13
Nov 22, 2006 05:47 PM
sleepingcivic90
49
Jan 21, 2005 09:55 AM
redzcstandardhatch
10
Nov 24, 2003 06:07 AM
sloweredcivic
Oct 16, 2003 03:27 AM
