Tranny fluid for LSD
Old Aug 20, 2007 | 10:11 PM
honda_mike's Avatar
Default Tranny fluid for LSD
Hey guys, is there any special tranny fluid to use on an LSD transmission? I belive its just a normal lsd transmission factory from honda, jdm sir tranny
thanks
Old Aug 22, 2007 | 11:56 AM
Bense's Avatar
stock honda MTF.
Specialty LSD trans fluid is for clutch based LSDs.
The stock LSD is a helical LSD. No special clutches
Old Aug 22, 2007 | 08:09 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: (Bense)
So Honda Tranny Fluid would be best? Bet it costs a lot of money Bense.
Old Aug 23, 2007 | 06:09 AM
civicomax's Avatar
Default Re: (HondamanXxX)
I'm wondering too, which oil I should put ! But I don't know what LSD I got ... I bought it and the lsd was there and it is not the OEM ... Should I put de MTL from honda anyway or don't take the chance and put an LSD oil to be sure if i dot a clutch lsd ?
Old Aug 23, 2007 | 09:02 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Bet it costs a lot of money Bense.</TD></TR></TABLE>
Less than $5 per quart. Not much at all considering you only need 3 quarts to do a B-series transmission, and the fluid doesn't get changed terribly often.
Old Aug 23, 2007 | 09:03 AM
Padawan's Avatar
Darth ModerVader
Default Re: (civicomax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicomax &raquo;</TD></TR><TR><TD CLASS="quote">I'm wondering too, which oil I should put ! But I don't know what LSD I got ... I bought it and the lsd was there and it is not the OEM ... Should I put de MTL from honda anyway or don't take the chance and put an LSD oil to be sure if i dot a clutch lsd ? </TD></TR></TABLE>
I'd verify what type of LSD you have before deciding on a fluid.
GO GIANTS!
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Less than $5 per quart. Not much at all considering you only need 3 quarts to do a B-series transmission, and the fluid doesn't get changed terribly often. </TD></TR></TABLE>
For the Honda Tranny fluid? Really?
Old Aug 23, 2007 | 09:20 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">For the Honda Tranny fluid? Really?</TD></TR></TABLE>
Yes sir. That's one reason why I can never understand why people insist on using regular motor oil. It's not difficult to buy the Honda MTF at a local Honda or Acura dealer, and you're saving a few dollars at most (depending upon which motor oil you compare it with).
Old Aug 23, 2007 | 09:21 AM
GO GIANTS!
Thanks man. I was told its expensive. Going to go buy some later today
Old Aug 24, 2007 | 08:55 AM
GO GIANTS!
Went to Honda today and they told me that Honda uses 10w-40 oil. I asked even with stock GSR LSD and he said yea so I bought 3. Hope it works.
Old Aug 25, 2007 | 09:52 AM
dannydos's Avatar
i have a quaife in my gsr...its not on the car yet....but what should i use....i also picked up some lsd fluid adder from the local part store...
Old Aug 25, 2007 | 09:54 AM
GO GIANTS!
Default Re: (dannydos)
I know if you ask some guys in the Drag Racing section they will answer you in no time. Some of them will also tell you to post in here tho.
Good luck.
Old Aug 25, 2007 | 10:06 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Went to Honda today and they told me that Honda uses 10w-40 oil. I asked even with stock GSR LSD and he said yea so I bought 3. Hope it works. </TD></TR></TABLE>
They lied to you, plain and simple. I would have gone to a different dealer where the employees actually knew what they were talking about.
To begin with, Honda now recommends MTF for all the manual transmissions, and prior to that, 10W-30 was used. If they're filling with 10W-40, they're wrong on two counts.
There is also no LSD in the GS-R transmission.
Old Aug 25, 2007 | 12:16 PM
91DA9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannydos &raquo;</TD></TR><TR><TD CLASS="quote">i have a quaife in my gsr...its not on the car yet....but what should i use....i also picked up some lsd fluid adder from the local part store...</TD></TR></TABLE>
Quaife is a helical LSD, same type as the stock LSDs, and as mentioned above, need no additives. Stick with the Honda MTF.
OP: Padawan is right on, do not use 10w-40. Even 10w-30 is merely listed as an alternative if Honda MTF is not available.
Old Sep 21, 2007 | 06:30 PM
GO GIANTS!
There is also no LSD in the GS-R transmission. </TD></TR></TABLE>
Hmm. Im starting to think the same thing. I am starting to grind into 3rd if I rev over 4,000rpm in 2nd gear. Its a JDM B18C with LSD tranny Man im screwed.
Old Sep 21, 2007 | 06:36 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Hmm. Im starting to think the same thing. I am starting to grind into 3rd if I rev over 4,000rpm in 2nd gear. Its a JDM B18C with LSD tranny Man im screwed.</TD></TR></TABLE>
Go to a local (but different from the previous one) Honda or Acura dealer, and ask for the new Honda MTF. Then drain and refill your transmission, and see if it improves. If it doesn't you can also try GM Synchromesh Friction Modified fluid, which many individuals have good results with.
Depending upon the condition of the transmission, it may need new synchros, but try the fluid first.
Old Sep 21, 2007 | 06:40 PM
GO GIANTS!
Ok will do. Also, where do you put the fluid into? I found a tiny hole but its very difficult to get a funnel into.
Old Sep 21, 2007 | 06:48 PM
Padawan's Avatar
Darth ModerVader
http://www.c-speedracing.com/h...d.php
Old Sep 21, 2007 | 06:51 PM
GO GIANTS!
Great thanks.
Old Sep 22, 2007 | 12:59 PM
GO GIANTS!
What do you guys think about the VTM-4 fluid? Used for the MDX and Pilot for differentials.
http://www.artsautomotive.com/GenuineFluids.htm
Old Sep 22, 2007 | 01:02 PM
Padawan's Avatar
Darth ModerVader
No, you want Honda MTF.
Old Sep 22, 2007 | 01:04 PM
GO GIANTS!
lol ok. Sorry im just making sure after Honda fooled me.
Old Sep 22, 2007 | 01:41 PM
Padawan's Avatar
Darth ModerVader
I borrowed this photo from another thread. Make sure those are the bottles you're getting from Honda. The GM fluid in that photo actually isn't the one I suggested, since it is not the Friction Modified forumula.
Old Sep 22, 2007 | 03:42 PM
GO GIANTS!
So how many bottles should I be putting in? And should I throw 1 GM one in? Whats the best to do?
Old Sep 22, 2007 | 03:50 PM
Padawan's Avatar
Darth ModerVader
I'd use Honda MTF for now (buy 3 quarts), and the instructions on filling the transmission are in the link I provided.
