TPS problem...and a question
Old Sep 27, 2003 | 08:17 AM
sivik2nr's Avatar
Default TPS problem...and a question
I'm getting a check engine light, so I pulled the code and it was a code 7. TPS sensor right? I searched and read through a lot of threads and now have a question... If I check the sensor with a multimeter and it doesn't read the 5V it's supposed to, can I use any TPS sensor? I have a '94 B18C in a '99 civic hatch. Or do I have to use an integra one? Can it be from an LS? ( is there any difference? )
I replaced the entire TB already because i broke the sensor when I took the engine out to do some rewiring. I got one from a junkyard. The original one had screws that could be taken out and the tps removed / calibrated. This TB that I have now has 'rivets' and it is permanently IN THERE. If i can find a teg TPS can i just , i don't know , BREAK out the old one and put one in with screws or something.
Otherwise are there any aftermarket TB that come with the sensors?
Old Sep 27, 2003 | 08:25 AM
simple4012's Avatar
New User
Default Re: TPS problem...and a question (sivik2nr)
they all will work fine as long as they are adjusted right
Old Sep 27, 2003 | 11:53 AM
B18CEG6's Avatar
JG/Edelbrock 85mm tb comes with a tps all ready calibrated $317
http://www.jegs.com/cgi-bin/nc...r=361
Old Sep 27, 2003 | 01:08 PM
realblag's Avatar
use a dremel tool to slot the head of the rivit looking thing. Its actually a bolt that the head pops off of when they torque it down. after you cut the slot, you can take it out with a flathead screwdriver.
Old Sep 27, 2003 | 03:48 PM
sivik2nr's Avatar
damn, that's some cool stuff... I will check out jegs too THANKS!!
team 15
Mar 13, 2007 12:00 AM
hondaeg8
May 14, 2004 10:23 AM
MassScene
Apr 27, 2004 05:08 PM
T-Mo
Sep 17, 2003 04:22 PM
