Timing Belt BS
Old Apr 5, 2023 | 12:12 PM
Fast510's Avatar
Default Timing Belt BS
Timing was way off on my first gen Integra. Cams matched but at #1 TDC the crank mark wasn't even close and the belt was loose.
I slipped the belt off the cam gears without having to loosen the tensioner, rotated the crank so that it was set correctly, and now the tensioner is tight and I don't have enough slack to slip the belt back over the cam gears.
I popped the plug and loosened the tensioner bolt to try and push it back down to get the belt on and I either dont have enough leverage or ... I have no idea.
How tf do I get the belt back on without having to remove the crank pulley and lower side cover because that sounds like a ton of bs.
purgat0ry
19
Aug 22, 2012 04:27 AM
yosuthnmasa
Apr 8, 2008 07:29 AM
Shaun
Jun 14, 2006 06:29 AM
GRAVEDIGGER
Jan 16, 2006 03:46 PM
Comptech98GSR
Oct 30, 2001 08:06 PM
