timing belt
Old Nov 9, 2003 | 07:52 AM
JONBLAZE55555's Avatar
Default timing belt
ok im setting the timming belt. i lined up the crankshaft pully at TDC. I did the same with the camshaft pully. I turned the crankshaft to put tension on the belt. when i checked it after puting tension on the belt it was off. it looked like only 1 tooth so i put it 1 tooth the oposite way and its then off 1 tooth the opposite way. what am i doing wrong?
Old Nov 9, 2003 | 08:03 AM
Default Re: timing belt (JONBLAZE55555)
bump
Old Nov 9, 2003 | 09:20 AM
doublejz's Avatar
make sure your belt is tight between the cam gears. This would throw you off. Also when you turn everything, before you tighten the tensioner you should only turn it like 3 teeth then tighten it down. It takes a while sometimes to get it perfect. My guess is that the cam gears are throwing you off, with either play between them or the lines aren't straight across
Old Nov 9, 2003 | 09:29 AM
Default Re: timing belt (doublejz)
on the crankshaft pulley does it mater if the lines are off .020 of an inch off?
Old Nov 9, 2003 | 11:15 AM
fasterb16hondasi's Avatar
yes
Old Nov 9, 2003 | 12:27 PM
Default Re: timing belt (fasterb16hondasi)
what will be the problem
7andaswitchblade
Jun 1, 2007 01:46 PM
NoVALude
Jul 19, 2006 11:53 AM
RCautoworks
25
Aug 15, 2004 09:17 PM
AdamITR
Aug 28, 2002 07:11 PM
Comptech98GSR
Oct 30, 2001 08:06 PM
