Is this thing ok? (big pictures)
Old Mar 17, 2003 | 05:59 PM
shingles's Avatar
Default Is this thing ok? (big pictures)
I won't post the story on here just yet.... but is this thing still ok?
ARGH!
not worried too much about this one.
It's a sleeved B18C1...
argh.... so pissed.
Old Mar 17, 2003 | 06:36 PM
TimoneX's Avatar
New User
Default Re: Is this thing ok? (shingles)
This is an engine building mishap...did you drop it?
Old Mar 17, 2003 | 06:38 PM
shingles's Avatar
Default Re: Is this thing ok? (TimoneX)
well I don't want to say exactly what happened just yet because I am trying to figure out what my options are.
but yes it was dropped.
Do you think the block is still usable?
-S
Old Mar 17, 2003 | 07:05 PM
TimoneX's Avatar
New User
Doesn't look terminal from what I can see. I'd swap out the crank girdle and inspect everything carefully for cracks.
Old Mar 17, 2003 | 07:14 PM
shingles's Avatar
Machine shop should be able to handle this?
Also, could the drop knock things out of alignment as far as the sleeves go?
-S
Old Mar 17, 2003 | 07:18 PM
TimoneX's Avatar
New User
Well the machine shop can magnaflux the block if that's what you're asking. I'd change the girdle myself if I were you. Just look for one at the junkyard or grab one off eBay...I see them cross there from time to time. I'd have the line bore checked at the shop as well...no sense taking chances.
Old Mar 17, 2003 | 07:26 PM
95hbMatt's Avatar
OUCH!! That sux man....
Old Mar 17, 2003 | 08:20 PM
Tbone's Avatar
If you have shown us all the damage, yes it looks fixable.
Old Mar 17, 2003 | 08:36 PM
shingles's Avatar
Default Re: Is this thing ok? (Tbone)
yeah that's pretty much it. the only thing tht worries me is the gridle. if it broke while on the block, I am worried about it hurting other things.
Old Mar 17, 2003 | 08:46 PM
Tbone's Avatar
Well you have to figure when they sleeve the block, its sitting right on those main seats where the caps bolt up too. They are under alot of pressure durring that process.
Old Mar 17, 2003 | 08:51 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
NO go on magnaflux deal, remember guys, the block is aluminum. in order to magnaflux you need an iron block.
Xray the thing i guess
stan
Old Mar 17, 2003 | 08:59 PM
TimoneX's Avatar
New User
Default Re: Is this thing ok? (90crxsi)
That's right...only the sleeves & crank could be done. I wouldn't bother then the sleeves are really solid.
Old Mar 17, 2003 | 09:11 PM
shingles's Avatar
The only thing that worries me is that the sleeves might have been knocked out of whack or somehow the whole block is cocked or something... it seems to me like the griddle isn't really that strong looking at how porous the metal is. It's probably plenty strong for what it was designed to do, just not support the weight of the block...
-S
Old Mar 17, 2003 | 10:14 PM
RangerDan's Avatar
Gosh thats a drag.
When them engines start to go...its takes about a tenth of a second then bang.
Good luck.
Old Mar 17, 2003 | 10:19 PM
Benny Hinn's Avatar
Default Re: Is this thing ok? (RangerDan)
**** UPS!
Old Mar 17, 2003 | 11:41 PM
AllmotorJunkie's Avatar
Default Re: Is this thing ok? (Benny Hinn)
Ewwwww!!! Its hard to see a beautiful block in such torn condition. That sucks...Hope something positive works out...
Old Mar 18, 2003 | 12:17 AM
Kamin's Avatar
Default Re: Is this thing ok? (AllmotorJunkie)
replace the girdle and have the block looked at by a machine shop
that second picture worries me, the crack/scratches(while they could be surface) are on the mating surface of head and headgasket...
Old Mar 18, 2003 | 09:07 PM
J2turbo21's Avatar
Looks like it fell down some stairs or something.Looks like some broken peices where the head goes and on the front.
Old Mar 19, 2003 | 01:06 PM
Stripped Honda's Avatar
99-0104
Default Re: Is this thing ok? (J2turbo21)
so let us know what happened to it .... we all are wondering !!!!! its gotta be a good story
Old Mar 19, 2003 | 01:50 PM
shingles's Avatar
Default Re: Is this thing ok? (Stripped Honda)
Three letters...
U
P
S
The block was packed as follows:
double boxes, thick boxes
wrapped/padded
additional cardboard padding around block.
I am not sure what happened, but it must have been a high drop to break the griddle like that...
-S
Old Mar 19, 2003 | 02:06 PM
TimoneX's Avatar
New User
That's about what I figured. UPS should be held accountable. GE uses wood on top and bottom for shipping for good reason and the girdle is fairly fragile, but that block obviously took a major league jolt to crack it in all those places.
Old Mar 19, 2003 | 02:17 PM
shingles's Avatar
I might be picking up Tbone's GE B18C.
This is pretty lame though... you figured if they just handled the box with car, you know not drop kick it, this would never happen and I would be a happy camper.....
Old Mar 19, 2003 | 02:34 PM
Tbone's Avatar
Just in case some of you missed my post about shipping blocks.
https://honda-tech.com/zerothread?id=283538
Old Mar 19, 2003 | 02:35 PM
Katman's Avatar
nah, it doesn't look like it.
MadCoder
Jun 7, 2011 05:50 PM
GSaura
Apr 11, 2007 08:18 PM
FOrSfEd
Mar 23, 2004 05:54 PM
jDMJeRk
Jan 22, 2004 11:24 PM
shingles
Mar 18, 2003 05:32 AM
