is there some sort of equation or rule to thumb on HP vs weight?
Old Jul 11, 2006 | 01:16 AM
FOUR-G's Avatar
Default is there some sort of equation or rule to thumb on HP vs weight?
how much horsepower does it take to make up for 300 pounds?
in other words, two cars have the same engine, but one car weighs 300 pounds more. or, if you add a permanent 300 pounds to your car, how much power would it take to compensate?
Old Jul 11, 2006 | 11:27 AM
Lsos's Avatar
Default Re: is there some sort of equation or rule to thumb on HP vs weight? (FOUR-G)
Whatever is necessary to keep the same power:weight ratio.
If you add 300lbs to a 300lb bike...well, you're going to need twice the horsepower to compensate. If the bike had 1hp, then you'll need another hp. If it had 100hp, you'll need 100hp.
If you add 300lbs to a school bus...you probably won't need very much horsepower to compensate.
Old Jul 11, 2006 | 03:48 PM
FOUR-G's Avatar
Default Re: is there some sort of equation or rule to thumb on HP vs weight? (Lsos)
so i'm overcomplicating it as usual.
so lets say i have 140 whp in a 2400 pound car, that's a 7:120 ratio. so i would need something like 17.5 whp to make up for 300 pounds in this example?
i get it. so that's 17.1 lbs per one hp.
ChrisShen
Oct 8, 2004 11:45 AM
SwitchCabNine
May 11, 2003 11:07 AM
HX_Guy
Sep 29, 2001 06:29 PM
HX_Guy
Aug 15, 2001 03:21 PM
