Tensioner pulley bolt question!
Old May 2, 2013 | 05:31 PM
joiv21's Avatar
Default Tensioner pulley bolt question!
Doing my b20/v when i went to put on my tensioner pulley bolt it started cross threading? i used the bolt from my b16, is it a different size for b20? surely not? right?
Old May 2, 2013 | 05:40 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Tensioner pulley bolt question!
Its possible they changed thread pitch... Are you sure both bolts are indeed for the tensioner?
Old May 2, 2013 | 05:56 PM
joiv21's Avatar
Got it threaded in there right, but then it decides to snap in half with half the bolt in the block. NOW WHAT? lol
Old May 2, 2013 | 06:11 PM
...Drill it out...
It obviously wasnt "threaded in there right"
Old May 2, 2013 | 06:38 PM
siblues's Avatar
Now you have to pull the motor. I had a similar problem in my em1 and I didn't have enough space to install a timesert so I can't imagine having enough space for a drill and bit. I would drill the bolt out but you are going to have to be very carefully not to make things worse then install a time sert.
Old May 3, 2013 | 04:55 AM
Charlie Moua's Avatar
sucks.
Even if you threaded the bolt in say 1/4th in or something it can still cross-thread.
i'm 99% you or someone else cross the threads from trying to apply upward tension to the tensioner with a flat screwdriver. Some people do this but apply too much force which ends up tilting the tensioner & when you try to tq it down it' cross-threads
take motor out, make sure to properly drill and use timeinsert. before putting motor back into car, use new tensioner bolt and tq to 41lbs to make sure it holds.
Old May 3, 2013 | 09:55 AM
joiv21's Avatar
Well motor is already out so it should be a breeze appreciate the feedback
Old May 7, 2013 | 09:01 AM
joiv21's Avatar
Well the bolt isn't coming out as easy as I wanted. So I tried the easeout technique drill a hole tap the easeout in there then turn and it's not working at all. Any other ideas? I heard a torch gun would damage the block if I used one? Really would appreciate feedback only thing holding my build
Old May 7, 2013 | 09:40 AM
Lizardslap's Avatar
take engine to a machine shop and just have them do it and not tear up the threads cost like 20$ or so per bolt but its worth the not aggravation of not getting that bolt out / tearing up the threads
California98Civ
Aug 6, 2014 06:00 PM
edcantu9
16
Sep 15, 2011 03:51 PM
Johnny Groovez
Sep 14, 2006 10:50 PM
D_CRX_Si
Mar 10, 2006 10:42 AM
XDEep
Sep 18, 2004 09:37 PM
