Teg LCA's for comptech sway/tie combo
if you have a 96-00 civic the integra lca's won't work on your car.
if your car came with a factory swaybar, then you don't need any extra parts. if not, just call a honda recycler and get the rear lca's with the hole in them.
(or put the hole in your stockers)
So basically I just need the one hole in each side to mount the tie bar too right? I have a 99 civic ex coupe. Does the Si have the hole already there? I think it does but i'm not sure. I was thinking about buyin the Si LCA's for the rear disc conversion.
the 99-00 si lca is a direct fit and does have the holes for the swaybar endlinks.
96 SOHC VTEC
Jun 12, 2002 01:04 PM
