tech question for injectors
Old Mar 15, 2003 | 07:20 PM
aesthetics82's Avatar
Default tech question for injectors
i need your help guys...im currently running a 2000 civic si with obd1 ecu and hondata with rc 550cc injectors...im gonna sell the turbo and go back to stock...i was told that when i change the injectors back to stock that i have to get new clips for the stock injectors because the ones i have now wont fit. is this true? can anyone confirm it and tell me how hard it is to switch the clips if needed...thanks.
-RJ
Old Mar 15, 2003 | 08:40 PM
CHEETAH's Avatar
Default Re: tech question for injectors (aesthetics82)
not necessarily, RC also sells OBD2 injectors so you may already have obd2 injectors to fit stock clip in there.
greg
Old Mar 16, 2003 | 03:09 PM
Default Re: tech question for injectors (CHEETAH)
thanks for the help...is there any particular way to tell if they are obd1 or obd2
Old Mar 17, 2003 | 02:15 PM
anyone know by looking at them to tell if the injectors are obd1 or obd2?
Old Mar 17, 2003 | 02:35 PM
Sonny's Avatar
If you are running RC550's, then you have OBD1 clips and either inline resistor wires or a resistor box.
All of that stuff has to come out to put the stock injectors back in. Who did the work for you?
Sonny
Old Apr 1, 2003 | 05:10 PM
Default Re: tech question for injectors (Sonny)
ok...i called rc and they said that they only have obd 1 clips for the 550cc. i got some obd1 injectors from an integra b/c they are the same as the Si injectors but they dont hook up to the obd 1 clips that i'm currently running (at least rc told me that they were obd1 clips). now i dont know if either the injectors are obd2 with obd 1 clips or the injectors are obd1 with obd 2 clips....is there a way to tell by lookin at the injectors if they are obd1 or obd2? i am gonna run obd 1 injectors so that i dont have to get rid of the resistor box and soder the wires. import builders did the work.
[Modified by aesthetics82, 6:13 PM 4/1/2003]
Old Apr 2, 2003 | 05:39 AM
CHEETAH's Avatar
obd1 vs obd0 are different but look similar. the 88-91 clips from hondas can interchange with 92-95 clips ... you most likely need 88-91 or any american plugs from the haltech, dfi, speedpro, etc ... if oyu need just pm me I'll sell you a set, send me pics of the injector themselves
greg
thaiphob
Aug 4, 2017 10:40 AM
EJ8 GSR-T
Apr 26, 2006 06:33 PM
cygnusX1
Nov 15, 2004 07:42 PM
