TB coolant bypass and idle surge
Old Mar 4, 2003 | 10:53 AM
Wicked Sol's Avatar
New User
Default TB coolant bypass and idle surge
I just bypasssd the coolant in the TB and iac and now my idle is bounceing from 800 to 3k rpms. I've heard of this happening to other people but does it happen to everyone? Is there anyway to stop it? The only rerason I did it was to make pulling the intake off easier and cleaner. What it I just fill the tb and iac wil coolant and plug the lines?
Old Mar 4, 2003 | 12:16 PM
ejprimo's Avatar
Default Re: TB coolant bypass and idle surge (Wicked Sol)
i cut out a piece of aluminum (beer can) the shape of the fast idle thermo valve and put it b/w the throttle body and FITV, then bolted everything back up. this solved all my idling issues when the motor is cold. now when ever i start my car my idle is always constant.
Old Mar 4, 2003 | 02:27 PM
Wicked Sol's Avatar
New User
Default Re: TB coolant bypass and idle surge (ejprimo)
I'll give that a try. But my car starts and idles fine when its cold but after it warms it it starts to surge.
Old Mar 4, 2003 | 02:38 PM
ejprimo's Avatar
thats was the opposite of my car. it would surge when cold and stay constant when warm.
Old Mar 4, 2003 | 10:22 PM
Wicked Sol's Avatar
New User
Maybe I just have a vaccum leak then. Thanks for the info.
Old Mar 5, 2003 | 04:34 AM
marc.ejay-twenty's Avatar
hey wicked sol, is it proven at all that the tb coolant bypass setup makes any extra power?
Old Mar 5, 2003 | 08:50 AM
sgT's Avatar
sgT
Default Re: TB coolant bypass and idle surge (marcdogg816)
I always remoev all coolant lines from the intake manifold as well as block the
coolant port in the head from the intake manifold. I see significant drops in air
temp on my datalogger.
Old Mar 6, 2003 | 01:24 AM
Wicked Sol's Avatar
New User
I can't really answer that for sure. I may make some but the main reason I did was because I'm removing the intake manifold just about every other week. and it just makes everything easier.
Old Mar 6, 2003 | 05:49 AM
JimBlake's Avatar
In PA this time of year you may need it to prevent TB icing...
JFantastic
Mar 11, 2013 08:15 PM
gregory
Oct 15, 2006 07:15 AM
gotsmokedright2
Feb 20, 2004 03:13 AM
hybrid901
May 29, 2003 07:20 AM
