tach problem
Old Nov 7, 2003 | 09:30 PM
brusso's Avatar
Default tach problem
Here's what's going on... I went to the track a few weeks ago and almost every time i hit 8K rpms my tach goes crazy bouncing all over the place. I took out the cluster and found the speed sensor wire cut and spliced together with another cut wire sticking out... so i replaced it with a clean wire which helped some because it used to freak out at 7 K and now it does it at 8K. Should i sauder the wire ? Can i run a direct wire from the msd... help.....
Old Nov 7, 2003 | 09:36 PM
sleepN's Avatar
you should solder it together. I do alot of tach installs and I always hook it up to the RPM wire from the ecu and it works really good.
littleblue
Nov 4, 2008 08:29 AM
1sikhatch
11
Mar 14, 2006 09:19 PM
Chiovnidca
Feb 16, 2006 03:09 AM
civiclxb16a
Apr 30, 2005 09:37 PM
