stupid question about Spoon head gasket.
Old Apr 23, 2002 | 01:06 PM
Russ713's Avatar
dAng!
Default stupid question about Spoon head gasket.
I just got a 'one-layer' Spoon gasket. It's black and has two layers of material. Does that sound right or is it truely a two layer?
Old Apr 23, 2002 | 07:06 PM
Russ713's Avatar
dAng!
Default Re: stupid question about Spoon head gasket. (Black Light)
out of all the 'technical' people in here, SOMEBODY'S got to have some sort of clue, right?
Old Apr 23, 2002 | 07:16 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
2 ply?
Old Apr 25, 2002 | 01:02 AM
carcala's Avatar
I thought those were discontinued! They probably sent you the two layer one since they discontinued it. Check with the place you got them.
Old Apr 25, 2002 | 08:19 AM
WAFFLES's Avatar
Default Re: stupid question about Spoon head gasket. (carcala)
It sounds like you got taken for a two layer head gasket. Damn, sorry about that.
Old Apr 25, 2002 | 08:26 AM
Russ713's Avatar
dAng!
Default Re: stupid question about Spoon head gasket. (WAFFLES)
baah, doesnt matter which one it really is. I'm not too concerned. I just wanted to find out which one it truely was so I could figure out what compression I would be running. I can always mill the head a bit to bump the compression up a touch to make up for the difference. Just didnt want to touch anything until I knew which one i got.
Old Apr 25, 2002 | 01:25 PM
glock's Avatar
New User
Quoted from inlinefour.com...
"The Spoon 1ply head gasket is measured at .40mm while the Spoon 2ply is measured at .45mm. Depending on your engines configuration, you can expect to raise compression levels by 0.4. This piece is not actually a 1 piece headgasket, it is only classified this way, because it's a 2 piece that is thinner than the actual Spoon 2ply head gasket."
Just measure your headgasket and find out for sure
Old Apr 25, 2002 | 03:45 PM
qtiger's Avatar
Default Re: stupid question about Spoon head gasket. (glock)
If you can measure .05 mm... my hat goes off to you. What is he going to do, hold it up to a ruler?
Old Apr 25, 2002 | 04:28 PM
EP3_05's Avatar
Default Re: stupid question about Spoon head gasket. (qtiger)
Use a caliper or micrometer...if he has access to one or the other.
Old Apr 25, 2002 | 05:40 PM
glock's Avatar
New User
Default Re: stupid question about Spoon head gasket. (91civic)
I found some pics...
Spoon .40mm headgasket
Spoon .45mm headgasket
I'm pretty sure he got the right one
[Modified by glock, 9:43 PM 4/25/2002]
Old Apr 25, 2002 | 07:05 PM
Russ713's Avatar
dAng!
sweet, glock, i most certainly appreciate that. you're the first person to get me all that info in about two days. In fact, you're the ONLY person.
Old Apr 25, 2002 | 07:07 PM
glock's Avatar
New User
No problem bro, I've been thinking about getting the .40mm gasket myself. Do you think its a safe/reliable way to raise compression?
Old Apr 25, 2002 | 07:11 PM
Russ713's Avatar
dAng!
i'm about to find out.
the way i see it, if it turns out i want to lower compression for forced induction, i can always go back to a stock or thicker gasket.
Old Apr 25, 2002 | 10:09 PM
Aklude_h22a's Avatar
using the spoon headgasket is fine if you dont mill the head, it like the mugen head gasket raises the compression safely, its fine for street use. make sure you get the low temp. thermostat and 1.3kg/cm² radiator cap also if you like to "race" the motor. Mugen or Spoon has both items. if you have problems finding it email me.
HiChanDC2R
Aug 31, 2010 08:28 AM
Ruben19
Apr 27, 2006 06:39 AM
lscoupe
May 2, 2005 08:23 PM
99MR_SiR
Dec 10, 2002 10:59 AM
snake01
Nov 13, 2002 03:26 PM
