Strut tower support (Tiebar y0!)
Old Feb 23, 2004 | 03:49 AM
rjardy's Avatar
Default Strut tower support (Tiebar y0!)
What is the optimum mounting point for the front upper tie? I looked at the factory bars that come with the CIVIC Si and GSR's, and they all mount right behind the strut mount, to the tower it self. I am sure I am wrong, but why do you not want to tie the actuall strut mount points together? I know some bars do this, but based on Honda's engineering knowledge, I assume that they way they have it is better. But why? It just makes sense in my mind to tie the top of the struts together, rather than 3 inches behind them, and tie the towers together. Pros and cons of both mounting positions are wlecome. Just wondering what you guys think.
Thanks
Rob
Old Feb 23, 2004 | 05:11 AM
rjardy's Avatar
Default Re: Strut tower support (rjardy)
anyone?
Rob
Old Feb 23, 2004 | 05:19 AM
rapid_roy's Avatar
In an Integra's suspension design, lateral loads are transmitted to the car via the upper control arm. The strut receives no lateral load so tying them together doesn't make much sense.
Cheers,
Sean
Old Feb 23, 2004 | 06:17 AM
rjardy's Avatar
Default Re: Strut tower support (rapid_roy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapid_roy &raquo;</TD></TR><TR><TD CLASS="quote">In an Integra's suspension design, lateral loads are transmitted to the car via the upper control arm. The strut receives no lateral load so tying them together doesn't make much sense.
Cheers,
Sean</TD></TR></TABLE>
That makes perfect sense. But then why would they tie the towers together right behind the strut mount? why tie the towers at all? It would make more sense to stifen the controll arm mount area.
rob
Old Feb 23, 2004 | 07:30 AM
suspendedHatch's Avatar
Some people seem to think that the load comes in at the UCA at the chassis mounting point and stops there, but in fact it twists the entire chassis and that's why we brace it. Your optimum mounting point on the front is the two larger bolts where the UCA is attached to the chassis at the strut towers. Thats what the Neuspeed bolts to. But you will still have a positive effect at diminishing chassis twist if you brace a different location.
sorwdfish
11
Aug 13, 2013 08:14 PM
SummerTaz
Mar 23, 2006 08:23 PM
Achenar
Suspension & Brakes
13
Aug 1, 2005 12:55 PM
MajorPayne
Aug 12, 2004 07:23 PM
TrueZen
Jan 30, 2004 02:17 PM
