spark plug wires coming out
background story....went to the drag strip and raced my car, next day car starts messing up, open up the distributor and rotor button screw is out, put it back in and everything's fine till car starts stuttering badly a few days later...turns out sparkplug wires are working themselves out
alright here's what's happening currently...seems like I made the problem worse...Saturday I drove almost 200 miles without a problem until I went and chased down a friend on the highway...at around 125mph it started to stutter (I should also not that the day after coming from the 1/8 mile drag strip I raced someone and as I was approaching higher speeds the problem began)...so I slowed and it kinda sorta went away...well the problem persisted, to where I had to push down the wires once twice a day, when I got to work and when I got home...it was always the first 2 and sometimes the 3rd spark plug wires that came out...so last night I take out all the spark plugs and clean them up as well as the inside of the spark plug wires...well apparently this made the situation a lot worse...5 times on the way to work (12 miles) I had to pull over and push down the plugs b/c the car was near stalling...once all 4 came out
now my question to you is what could be causing this? btw the engine is a B16b with about 60k miles and I'm using NGK Iridium spark plugs with some wires I got from Autozone...I've had these on my car since November and made 9 runs on the 1/8 mile dragstrip on March 5th, on March 6th is when the problems began
Cause= cheap spark plug leads, the terminal that is supposed to clip onto the spark plug is loose, it has "opened up" and no longer "clips" on.
You may be able to crimp them so they will clip on but they will loosen up again, I would replace them.94
well went to Advanced Auto to buy some wires but they only had the ones i bought from Auto Zone, but they
had 1 set of NGK's at another store, so i laid a rag i had in the trunk over the plugs, screwed down the sparkplug
cover and headed 10 miles down the road...so now i have new NGK spark plugs and wires...seems to have fixed the problem...thanks for the help
good deal. now you can also zip tie the spark plug wire part that goes over the dizzy. i've had it where it slipped out a few times and that can screw up your ECU. just my two cents.
