sometimes i cant get back into first gear.
Old Mar 20, 2003 | 04:04 PM
weakGOODJunKieS.com's Avatar
Default sometimes i cant get back into first gear.
when im at a stop sign (ive also stopped completely) and then its my turn to go, i cant put the car into gear, when i try to it gets "stuck" about half way and then when i try to step on the gas it grinds, after it grinds, i can then put it into gear. what is this?
Old Mar 20, 2003 | 04:38 PM
altoid's Avatar
Default Re: sometimes i cant get back into first gear. (98-DC2)
what works for me is going into second then into first. sometimes i cant get into second, so i go 3-2-1.
Old Mar 20, 2003 | 04:41 PM
M-EJ1's Avatar
Default Re: sometimes i cant get back into first gear. (altoid)
What are you using for manual tranny fluid? I had similar problems (notchy shifting, problems getting into first at low speeds, etc) when I was running 10w30 motor oil like my chiltons manual recommends. Just for kicks I flushed it and replaced it with Honda MTF and it's like night and day.
Old Mar 20, 2003 | 06:24 PM
cjohnson_2's Avatar
Default Re: sometimes i cant get back into first gear. (M-EJ1)
Mine does the same thing.. I am just guessing that the gear is wearing out?? but like the other posts say I just throw it in 2nd and then back up to first. almost always works then
Old Mar 20, 2003 | 07:07 PM
TREVER's Avatar
Default Re: sometimes i cant get back into first gear. (cjohnson_2)
The 2 then 1 shift and snap the throttle a little. Use honda mtl.
Old Mar 20, 2003 | 07:08 PM
dfoxengr's Avatar
reverse is a huge problem for Bseries trannies too, getting into gears slowly is the reason ive figured out..it sux and grab a little
mula10390
Jun 20, 2018 03:02 PM
mk818
Aug 27, 2012 08:37 AM
Rpizzle
Apr 11, 2005 03:24 PM
crzyfool24
11
Sep 26, 2004 09:48 PM
RTW DC2R
Sep 14, 2003 06:02 AM
