SOHC vtec head
I am going to look at one tomorrow that i might buy for a mini-me swap. The guy says it is not together but has everthing but vtec solenoid and cam gear. Anything i should look for when i check out the head? How much do the solenoids run. Any input helps. The head is off a 92 ex
makesureall the pins in the rocker arms are there...make sure that the cam journals are not killed...look for severe mating surface marrs, or obvious machining marks (ie- un-deburred coolant passage entries, half circle shapes on the mating surface (you dont want a head that was milled so much its junk)
i say get a head that is togetehr if you dont know what to look for....no offense, but its a lot easier to get a complete piece that requires no guessing
mudpuppy4life
Jun 9, 2011 07:19 PM
g-ride-si
13
Sep 11, 2006 01:27 PM
