sohc motor question
Old Aug 13, 2009 | 06:59 AM
Kris's turbo's Avatar
Default sohc motor question
My sister hydro locked her 2000 ex and so I have a d15z1 motor from a 93 vx at the house with bad pistons and I was thinking of just changing the pistons from the d16 to the d15 and putting that in her car to get it running. Will it work? Thank you for your help.
Old Aug 13, 2009 | 07:43 AM
twentyhurtz's Avatar
Default Re: sohc motor question
i'm not expert, but i'm thinking the d16 pistons are going to be larger in diameter, because the block height is probably the same.
Old Aug 13, 2009 | 07:55 AM
jjspec's Avatar
The block height is different. The bore size is 75mm on both. I am not sure about the compression height.
Old Aug 13, 2009 | 11:44 AM
Psychoteen101's Avatar
Its not worth the labor. You can find a D16 for under $400 most of the time, might as well just do that.
hondaex00
Jun 9, 2006 12:44 AM
RICE POLICE SIP
Feb 25, 2006 07:42 PM
ottomaticjack
Feb 1, 2004 07:08 PM
91hondacrx
Jun 18, 2003 03:08 PM
