Sohc/Dohc transmission vs. SI d Series trans. (difference)
do you mean zc (sohc) or zc (Dohc)
zc(sohc) should have the smaller diff. hole
zc(dohc) has the larger differential.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FIGARILA »</TD></TR><TR><TD CLASS="quote">do you mean zc (sohc) or zc (Dohc)
zc(dohc) has the larger differential.</TD></TR></TABLE>
well yeah...... i wanted to compare the soch, doch and SI... i think the sohc has the same diameter as the SI but the dohc has a bigger diff diameter then both right?. if thats the case how do i check if mine is the sohc zc instead of a n SI (i got it from a complete swap so i think its Sohc zc tranny. thanks for ur help in advance
