SOHC Cam Gears
Is it worth the 80$ to buy a skunk 2 or AEM cam gear off ebay. and just by installing it do you gain hp? or does it have to be tuned by a tuner? If so what kind of tuning would i need done? How much would this tuning cost? thanks...ya i know im not the most eduactated but that is why im asking for help...still in HS. Also whats a better cam gear...skunk 2 or AEM...
I drive a 97 civic hx
cai,headers,exuast...plan on doing a mini mi swap with a port and polished d16y8 head.
with what you mentioned above Ferby, and w/ Dyno tuning you could probably warrant 10+ HP.... w/ just the cam gear not much, as w/ the SOHC you will only be helping on the bottom end or on the top end of he RPM band.
Unlike w/ a DOHC you can then adjust the intake and exhaust cams.
Good luck man...
Good luck man...
sohctodohc
11
Jun 5, 2005 07:47 PM
South Bay Surfer
15
Mar 29, 2003 06:17 AM
