sohc bore
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon »</TD></TR><TR><TD CLASS="quote">rofl 1.8-2.0 sohc engine ...thats a good one.. the displacement has to do way more with the rod ratio and crank ratio than just the bore. fyi</TD></TR></TABLE>
shut up is it possible or what
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakitori »</TD></TR><TR><TD CLASS="quote">
shut up is it possible or what</TD></TR></TABLE>
LMAO hahaha
LMAO hahaha
do you have a phone number i reach you? i'm a trial member, i can't reply to your post on classified section. i've tried both of your emails but can't get through. i'm interested in your car with the h22 swap. call me at 585-738-8921 or email me your numbers at http://www.nik_rek@yahoo.com. thanks. derek
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakitori »</TD></TR><TR><TD CLASS="quote">whats the max you can bore out a single cam engine to? in this case d16z6 if that makes any difference. and is it possible to make a 1.8 or even 2.0l sohc engine?
I know a 77mm bore d16 will yield about a 1.7xl motor.
When i talked to rs machine about getting my project car sleeved they said they have bored all motor (d16) cars as much as 80mm.
i dont have the equation on me but im pretty sure an 80mm bore d16 will yield close to 1.8l.
</TD></TR></TABLE>I know a 77mm bore d16 will yield about a 1.7xl motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psileepR »</TD></TR><TR><TD CLASS="quote">
i dont have the equation on me but im pretty sure an 80mm bore d16 will yield close to 1.8l. </TD></TR></TABLE>
wow thanks for the info psileepR stupid dicks like that other guy are useless on this board and should be BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by minirek »</TD></TR><TR><TD CLASS="quote">do you have a phone number i reach you? i'm a trial member, i can't reply to your post on classified section. i've tried both of your emails but can't get through. i'm interested in your car with the h22 swap. call me at 585-738-8921 or email me your numbers at http://www.nik_rek@yahoo.com. thanks. derek
yea my AIM is SOLCHLMP reach me there or email me jamesoda_eg6@hotmail.com
From: the asshole of america..., upstate new york, USA
without sleeving the block, i think .5mm overbore is supposed to be a safe limit.
but if you sleeve to 79mm and use a d17 crank of 94.4mm stroke...this give you a 1.85L. 80mm & 94.4mm = 1.89L 80mm & 90mm = 1.81L
i dont know what rod ratio has to do with displacement?
A machine shop here in Toronto has sleeved a D16 and bored it to 81mm.
This allows you to drop in B18A/B rods and pistons. I understand it is about 1.9 litres, and I'm told is between 11 and 12:1 comp...
Quite a sleeper in a CRX...
Scracho
Aug 27, 2013 08:39 AM
bspeed
42
Sep 24, 2004 04:56 PM
z6
May 14, 2004 09:32 AM
