sloppy steering...possible causes?
Old Jul 10, 2006 | 07:19 AM
.RTErnie's Avatar
Default sloppy steering...possible causes?
I can turn my steering wheel approx. 30 degrees with NO response whatso ever. What is this caused by? I replaced my outer tie rods...Im soon to replace my inner tie rods.
Do I need to have my rack rebuilt? check the joints in the steering wheel? Any place I could take it to that would fix it for relatively cheap? It's VERY unsafe when you're trying to stay within one lane and boosting out of control. thanks!
Old Jul 10, 2006 | 07:34 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: sloppy steering...possible causes? (~RTErnie~)
if you have PS i know air in the PS lines will play some weird trick's on you..check that out first it's cheap, but 30 deg air may not be the prob
Old Jul 10, 2006 | 08:01 AM
.RTErnie's Avatar
Default Re: sloppy steering...possible causes? (DBL)
manual rack... so no lines.
Old Jul 10, 2006 | 12:41 PM
robbieshonda's Avatar
The gear box section is going out. You can still use it just over steer. I'd replace it.
Old Jul 10, 2006 | 03:02 PM
rainforest's Avatar
Default Re: sloppy steering...possible causes? (robbieshonda)
well i wouldent go and replace it that quick. lift the car in the air then grab the rim at the 3 and 9 o clock postitions and rock it back and forth there should be no slop in the suspension if there is check the outter tie rod ends first then visually insect the bushings and mounts. if you see nothing wrong i would then decide to replave the rack.
Registered user
Nov 17, 2016 05:02 AM
gsrswap
Nov 27, 2011 08:26 AM
4genblack
11
Jun 6, 2004 01:52 PM
jabroni95gsr
Feb 13, 2003 04:12 AM
Martaigne
Jun 14, 2002 07:07 AM
