Skunk2 Stage 2 valve adjustment
Old Jun 14, 2006 | 04:59 PM
MenaceL.A.671's Avatar
Default Skunk2 Stage 2 valve adjustment
yup i got the s2s2 cams and on the box it says to adjust the valves to .007in. and .008ex both cold! installed! and right when i was done i warm up the motor and yeah i can hear my taplets? so do i adjust it to .006in and .007ex? or is that normal to hear the taplets its kinda loud! thanks!
Modified by MenaceL.A.671 at 12:24 PM 6/15/2006
Old Jun 14, 2006 | 06:50 PM
JisatsuGuy's Avatar
Default Re: Skunk2 Stage 2 valve adjustment (MenaceL.A.671)
well, thats their specs cus those are higher rpm cams, try a tight 7 but loose 6 and so on. too tight and u can wear the cam. ive seen crower cams in a h22 with the lobes starting to grind down, it was nasty. hth, chris
Old Jun 15, 2006 | 06:30 PM
Default Re: Skunk2 Stage 2 valve adjustment (JisatsuGuy)
its alot better i use .006in and .007ex.. cant hear it no more!
veilsides2000
Jul 26, 2005 06:30 AM
JDMotive
Jun 5, 2004 10:14 PM
THCk20eg
May 23, 2004 10:13 PM
PYITR821
Mar 1, 2004 10:18 PM
sleepycivix
Nov 15, 2002 07:01 PM
