skunk2 pro series 70mm TB idle problem
Old Oct 23, 2013 | 07:55 PM
reg_lus's Avatar
Default skunk2 pro series 70mm TB idle problem
After putting on the skunk2 pro TB. car idles at 1300 *Steady Idle*
I tried to calibrate the tps to .50 (stock) closed but it only goes as far as .68 for the lowest it can go. it wont go any lower than that. on a cold start, it sits right 1000rpm. when warmed up, it sits at 1300rpm. and the idle screw pen is closed too...any clue?
Old Oct 24, 2013 | 11:46 AM
reg_lus's Avatar
Default Re: skunk2 pro series 70mm TB idle problem
bump.
no one ever experienced this?
Old Jul 17, 2022 | 10:03 AM
dameon fochtman's Avatar
the tps probably wasn’t correctly sitting in the fork but was most likely sitting on top of it and it will still read that way but be incorrect, or the sensor it potentially bad
krazy one
32
Sep 6, 2010 09:10 PM
UK_Luder
Jul 24, 2007 09:08 AM
snowblind7x
Jul 12, 2006 06:52 AM
civicsi0721
Jun 20, 2006 09:35 AM
sirshan
Mar 16, 2006 01:32 PM
