Skunk 2 primary/secondary lobe specs
Old Feb 11, 2003 | 07:50 PM
Yellow00TypeR's Avatar
Default Skunk 2 primary/secondary lobe specs
I am looking for the specs for the primary and secondary lobes on Skunk2 stage 2 and stage 3 cams. Does anybody have them or know a site that has them posted?
Old Feb 17, 2003 | 08:50 PM
ping83's Avatar
Default Re: Skunk 2 primary/secondary lobe specs (Yellow00TypeR)
go to http://www.allmotorhonda.com that have all kinds of specs and what not.
Old Feb 17, 2003 | 10:36 PM
dfoxengr's Avatar
look around???..::: off inlinefour.com
SKUNK 2 STAGE I SPECS:
INTAKE: DURATION @ 1mm 252º LIFT: 0.456"(11.5mm)
EXHAUST: DURATION @ 1mm 249º LIFT: 0.426"(10.8mm)
VAVLE SETTINGS
Lash the valves to stock settings on a cold motor
INTAKE: 0.007in.
EXHAUST: 0.008in.
SKUNK2 STAGE II SPECS:
INTAKE: DURATION @1mm 266º LIFT @ 0" lash: 0.485(12.3mm)
OPENING @1mm: 37º BTDC
CLOSING @1mm: 49º ABDC
EXHAUST: DURATION @1mm 262º LIFT @ 0" lash: 0.466(11.8mm)
OPENING @1mm: 61º BTDC
CLOSING @1mm: 21º ABDC
VAVLE SETTINGS
INTAKE: 0.007in.
EXHAUST: 0.008in.
SKUNK2 STAGE III SPECS:
INTAKE: DURATION @1mm 270º LIFT @ 0" lash: 0.504(12.8mm)
OPENING @1mm: 35º BTDC
CLOSING @1mm: 52º ABDC
EXHAUST: DURATION @1mm 279º LIFT @ 0" lash: 0.465(11.8mm)
OPENING @1mm: 62º BTDC
CLOSING @1mm: 32º ABDC
VAVLE SETTINGS
INTAKE: 0.007in.
EXHAUST: 0.008in.
[Modified by hybridvteceg, 2:37 AM 2/18/2003]
Old Feb 19, 2003 | 06:20 PM
Default Re: Skunk 2 primary/secondary lobe specs (hybridvteceg)
Those are specs for the VTEC lobes on the cams. If you read my post you would see that I was asking for the specs on the primary and secondary lobes not the VTEC lobe. Thanks anyway though.
Old Feb 19, 2003 | 07:50 PM
dfoxengr's Avatar
yeah thats all we could find....call up skunk...
Old Feb 19, 2003 | 08:59 PM
I already E-mailed them but haven't got a response. If I find out the specs I will post them.
Natural Aspirations
Apr 26, 2016 09:47 PM
towns
Nov 26, 2004 02:05 AM
donpeters
Jul 11, 2004 05:49 AM
slofu
Sep 27, 2002 11:21 AM
ghettoracer
Jan 31, 2002 06:04 PM
