sizing bearings on 2000 b16a
please help im building a 2000 b16a for turbo and i need some help sizing the bearings.
should i buy new ones that are the same that came out and start measuring there or should i measure the used ones that came out of my motor and start from there my crank has been machined and micropolished and so have all the bearing journals so im sure that i will need larger bearings please help thanks |
Re: sizing bearings on 2000 b16a (egcivicturbo)
Buy one new set - doesn't really matter what size, say green for example - and measure all the journals using it. Then according to the readings, buy bigger or smaller bearings for each journal.
Here's instructions on how to do it: http://www.c-speedracing.com/howto/b.../bearings.html |
Re: sizing bearings on 2000 b16a (G3-TEG)
thanks a lot that helped out now i know what im doing
thanks again |
