Old Mar 25, 2015, 11:00 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Simple DIY start circuit test, [bypass jump]
Old Mar 9, 2015 | 10:41 PM
  #26
ky335's Avatar
Default Re: Simple DIY start circuit test, [bypass jump]
nice write up! will come very useful too me
Old Apr 17, 2015 | 06:29 PM
  #27
Shelbynicole's Avatar
Thanks it was useful
Old May 18, 2015 | 01:04 AM
  #28
phootbag's Avatar
My professional opinion is that a voltage drop test is far more informative than using a test light. Most test lights will illuminate below 12 volts.
An unwanted voltage drop in a circuit such as a pinched wire or corroded connector may support the current necessary to illuminate a test light, it may not, however, be sufficient to support the current necessary to energize the starter solenoid.
A test light may not indicate this unwanted voltage drop whereas a multimeter or power probe with a display will indicate a voltage drop. And this is exactly why my test light has not seen the light of day in almost two decades.
Old May 16, 2016 | 06:58 PM
  #29
redcivic's Avatar
If the solenoid is not getting 12V then what exactly could it be? My sons GSR has the same issue, starts if you jump the solenoid to the battery, relays are all tested and good, clutch switch is good, starter is new.
I will test the voltage next or should I check continuity on the wire to the starter solenoid?
Thanks.
Old May 18, 2016 | 03:09 PM
  #30
1980Jeep's Avatar
Thanks for all the help. I will give it a shot. Thank you
Old May 30, 2016 | 09:37 AM
  #31
redcivic's Avatar
OKay guys I am at a loss.
IF I jumper the connector at the relay it fires right up when I turn the key. I bought a new relay and it still does not start with the relay plugged in. Any ideas?
Old Aug 20, 2016 | 08:52 AM
  #32
fcm's Avatar
fcm
Old Fart
Check the CIS, [clutch interlock switch] it supplies the ground, [when clutch stepped on] for the starter relays coil. 94
Old Oct 23, 2016 | 07:12 PM
  #33
ZMoney444's Avatar
Anybody ever figure out what the issue is if honda isn't cranking but starts right up when jumped from battery to starter terminal? I've got a 03 Accord EX V6 and key wont crank engine but jumper lead from battery to starter works every time! Help!!!
Old Aug 20, 2017 | 06:45 PM
  #34
koyan123's Avatar
Hi, are you able to do the test (starter) without taking out the intake manifold on the honda crv 02-06?
Old Jul 2, 2018 | 12:25 PM
  #35
dirtracer65's Avatar
Normally, if you can jump from the spade terminal on the starter solenoid to the battery connection on the starter with a screwdriver and the engine turns over, it's most likely a starter solenoid issue.
Does anyone know how to wire around a 98 Prelude ignition switch? I am running my Prelude in dirt track races. I had to change engines and after I reconnected all the wiring, the fuel pump would run in the off position of the ignition switch. Has anyone experienced this trouble before? What did you do to correct the issue? Thanks
Old Jan 15, 2019 | 07:58 AM
  #36
grilledcheese's Avatar
so awesome thank you for this!
Old Nov 30, 2019 | 04:12 PM
  #37
1995hondacivic1's Avatar
nice to know for future reference
Old Jun 4, 2024 | 09:25 PM
  #38
B20VNelly's Avatar
Good info 🤙🏻
Oolong
10
Jan 28, 2018 06:05 PM
roe999
Dec 23, 2008 05:08 AM
pinricky
Feb 4, 2006 02:54 PM
eh3 93
Jun 4, 2003 04:20 PM
Int3Gra147
Apr 30, 2003 12:37 PM
