should a hasport ef-b engine mount be this crooked?
Old Jan 9, 2010 | 09:01 PM
kelsodeez's Avatar
derp resistant
Default should a hasport ef-b engine mount be this crooked?
im looking for some input on this situation. i test fitted up the mounts and it looks ridiculously crooked for some reason. i dont think the engine will sit correctly like this. does it matter that its a jdm b16b? any input is appreciated before i write to hasport about this.
Old Jan 9, 2010 | 09:06 PM
locash's Avatar
Default Re: should a hasport ef-b engine mount be this crooked?
You have the wrong engine mount bracket. The EF mount you have is designed for the 90-93 Integra style bracket (one stud, one non-threaded hole). Buy that engine mount bracket from Acura, and you'll be fine.
Old Jan 9, 2010 | 09:19 PM
kelsodeez's Avatar
derp resistant
but if the mount was made for a bracket with one stud one bolt, wouldnt one hole be smaller than the other? the holes on the hasport mount are both the same size. here is what the mount for a 90-93 gsr looks like. notice the different sized holes
Old Jan 9, 2010 | 09:33 PM
boostedEF91's Avatar
b16b is out of a ek. you need to change bracket off the motor. you need a bracket from a OBD0 B16. or from a DA integra
the soL that could
Welding / Fabrication
Aug 21, 2011 09:12 PM
jaskuloski97sh
Jul 20, 2007 09:30 PM
