selecting bearings...
Old Jan 22, 2007 | 03:11 PM
ilikebigbutts's Avatar
Default selecting bearings...
ok i'm trying to figure out what kind of bearing i'm suppose to use.I'm using aftermarket rods so i can't go from the numbers on my stock rods.i read somewhere that when you are using aftermarket rods green bearings should be ordered.For the mains i'm just going with the colors that i'm suppose to use according to the letters/numbers on the block/crank.
this is on an f22a6.
any comments/suggestion apreciated.
ILBB
Old Jan 22, 2007 | 07:55 PM
HiProfile's Avatar
Default Re: selecting bearings... (ilikebigbutts)
Your best bet for price will be ACL's (if they make them for that) + any OEM bearings if you have one out of spec. 2nd would be an OEM set according to your codes, but with an extra + and - size set from an OEM internet supplier. My local stealership charges full 'retail' for them, but has to special order them, taking the same amout of time as the internet places usually do.
Stay away from other brands, they tend to vary quite a bit for clearances.
GruvyTune
Engine Machining & Assembly
14
May 22, 2020 09:28 PM
eg:R
Sep 14, 2006 09:36 AM
b20vtech
Feb 21, 2006 07:57 PM
- Sim -
Dec 29, 2004 11:43 PM
totalimpact
Nov 11, 2003 06:39 PM
