Secondary o2 sensor
Old Jan 31, 2003 | 09:54 PM
Hatebreed215's Avatar
Default Secondary o2 sensor
Just put a y8 into my 96 civic dx...to make things easier we used a new y8 engine harness and my old y7 header/cat....the primary o2 sensor is pluged in and running fine but the second o2 sensor after the cat is pluged into the cat but has no conector to clip into....there is no conector on the engine harness for the second o2 sensor after the cat....does the stock y8 sensor go to a connector through the floorboard and plug into the cabin harness? If so, i dont think i have that connector on my y7 cabin harness. What should i do to send the readins from the sensor to the ecu?
Old Feb 1, 2003 | 01:12 PM
Default Re: Secondary o2 sensor (Hatebreed215)
^bump
Old Feb 1, 2003 | 04:03 PM
b19coupe's Avatar
If you are running an OBD1 setup, the secondary oxygen sensor is not needed or used. If you are running OBD2, there should be a connector for it under the passenger seat.
Old Feb 2, 2003 | 08:20 PM
salbaje's Avatar
which ecu are you using?? if its obd 2 then you would need to run the wires to the ecu
Old Feb 3, 2003 | 02:35 PM
Default Re: Secondary o2 sensor (salbaje)
im running a p2p in the 96 civic dx w/ y8 motor
the sensor is suposed to plug into a conector near the passanger seat but i dont have the conector on my cabin harness.....honda wants like $240 for a new 2 wire secondary sensor so i think i gotta find a new way to trick the ecu so i dont get a cel light
92siturbro
24
Mar 6, 2014 09:38 PM
FRKWOO
Oct 11, 2009 12:00 AM
viskii420
Sep 16, 2006 06:10 AM
exare250
Nov 24, 2004 10:59 AM
