Rust on block sleeve. Piston seized. Need Help.
Old Dec 17, 2013 | 06:18 AM
Luward's Avatar
Default Rust on block sleeve. Piston seized. Need Help.
I've searched around the web and on HT and I'm not able to find the information I need. What I got is a B18b block. Picked it up from a guy for free. He left the block sitting outside in the rain/snow and cylinder 1 and 4 has rust all over it. With cylinder 1 and 4 having rust, the piston is completely seized up and won't move. I've tried putting some oil in the cylinder and letting it sit there for a day or two, but it seems like its not wanting to seap through. I've read about using 1/2 and 1/2 of oil and gasoline and setting it on fire, but I'm afraid it may expand the cylinders to much and making the block scrap. Any suggestions will help. Thanks.
Old Dec 17, 2013 | 07:15 AM
doood's Avatar
been there done that
Default Re: Rust on block sleeve. Piston seized. Need Help.
if the rust is as bad as you say it is, the block may already be scrap, short of resleeving it.
Old Dec 17, 2013 | 07:29 AM
stenseltizm's Avatar
I've used PB blaster and a breaker bar on the crank pulley nut to slowly work them loose.
If its rusted that bad the block probably isn't going to clean up with a simple hone though. To be perfect you'll be into a new set of pistons and a bore, at that point I usually find it cheaper to pick up another block for $20 that will clean up with just a hone.
If you don't mind a little pitting showing after the hone, break it loose, hone it, and run it.
Old Dec 18, 2013 | 03:05 AM
hondamark35's Avatar
Originally Posted by Luward
... I've tried putting some oil in the cylinder and letting it sit there for a day or two, but it seems like its not wanting to seap through. I've read about using 1/2 and 1/2 of oil and gasoline and setting it on fire, but I'm afraid it may expand the cylinders to much and making the block scrap. Any suggestions will help. Thanks.
engine oil at ambient temp is too thick to get in there. you could try 200° oil... or a mix of ATF and acetone. ATF/acetone mix outperformed commercially available penetrating oils in a test done by a machinist magazine. or so the story goes. I've tried it and it does work very well. pour some in, let is soak over night then try working it loose like stenseltizm suggested.
Old Dec 22, 2013 | 09:39 AM
jdmconcepts's Avatar
Get yourself some marvels mystery oil that will do the trick. You can pick that bad boy up at any autoparts store. Pour it in and let it sit that should seep through and break it loose.
Old Dec 22, 2013 | 05:51 PM
preludeNApower's Avatar
You can try heating up a rod, red hot and inserting it into the cylinders to expand the cylinder and then try turning it over. I have done this to press sleeves in.
Old Dec 22, 2013 | 06:06 PM
SPA Motorsports's Avatar
you can try using a product called FREEZE-OFF it works wonders the can find it at autozone for under $10 we also recommend after unfreezing the block you should have it honed to clean up the cylinder walls!!
Hope this helps
SPA Motorsports
hYbRid_Eg6
Oct 26, 2010 04:57 PM
boosted_dc2
Jan 27, 2004 09:36 PM
GapxGuy
Dec 26, 2002 05:32 AM
shingles
Oct 22, 2002 08:25 PM
Apex i ITR
Aug 12, 2002 01:34 PM
