RPM and MPH NEEDLE JUMPING
Old Feb 23, 2006 | 06:25 AM
LSVtecHatchback's Avatar
Default RPM and MPH NEEDLE JUMPING
well sometimes my rpm needles jump and the same with my MPH needle..i think i need better spark plugs but im not sure..can it also be my dist?my car is a turbo b20 FYI
Old Feb 23, 2006 | 08:03 AM
AL ASPIRATED's Avatar
Default Re: RPM and MPH NEEDLE JUMPING (LSVtecHatchback)
it can be from the crank position sensor from ur dist or vehicle speed sensor or cable wat car is it in?
Old Feb 23, 2006 | 08:16 AM
Default Re: RPM and MPH NEEDLE JUMPING (AL ASPIRATED)
integra
Old Feb 23, 2006 | 08:17 AM
my car was also stolen and they took the vtec controller out would that have mess some of the wiring up?
Old Feb 23, 2006 | 08:37 AM
j0hnniz's Avatar
you have a messed up wiring problem. same thing happened to me, there was a short that i had to fix on my TYpe R back in the day. Also, try checking the Alt/Speed Sensor fuse.
Old Feb 23, 2006 | 03:37 PM
Default Re: (j0hnniz)
were is that located?
Old Feb 23, 2006 | 06:20 PM
sc4dr's Avatar
If its the vss, it would throw a code...unless its not prolonged. Check for corrosion on your vss on top of your tranny
Old Feb 23, 2006 | 07:50 PM
Default Re: RPM and MPH NEEDLE JUMPING (sc4dr)
alright ill do that tomorrow
senser1080
Jan 2, 2010 07:26 PM
doubleoazn03
Sep 5, 2008 10:33 PM
silentblackhat
Dec 25, 2005 05:29 PM
SPOON_FED_DC_2
Jul 29, 2004 01:13 AM
dvsluder
May 28, 2004 05:42 AM
