Rotor Question
Old Dec 27, 2003 | 07:03 AM
Bizarre's Avatar
Default Rotor Question
Will 92 Gsr rotors fit a 94 gsr?
Old Dec 28, 2003 | 05:11 AM
Bizarre's Avatar
Default Re: Rotor Question (Bizarre)
Bump
Old Dec 29, 2003 | 02:24 PM
Bizarre's Avatar
Up
Old Dec 29, 2003 | 02:38 PM
EJ1_519
Guest
Posts: n/a
For some reason, I'm thinking they would
Old Dec 29, 2003 | 04:45 PM
Kendall's Avatar
Why would you want to? Is there a significant size difference?
Make sure that the rotor thickness is either the same or very very very close. And also make sure that all of the pad will be on the rotor. Also double check the offset of the rotor and make sure that it is the same as the newer ones. You can't be too careful when it comes to brakes, personally I'd buy a set that I knew would fit.
Old Dec 29, 2003 | 05:08 PM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bizarre &raquo;</TD></TR><TR><TD CLASS="quote">Will 92 Gsr rotors fit a 94 gsr?</TD></TR></TABLE>
yes they will fit, and there is no size difference.
Old Dec 30, 2003 | 09:13 AM
Bizarre's Avatar
Not buying. Was just curious cause I had a brand new set laying around.
Thanks for the replies guys.
morepoop4u
Jan 13, 2006 09:43 PM
94LS_allmota
May 1, 2005 10:09 PM
Driven
22
Oct 10, 2004 02:42 PM
TurboEg
Aug 4, 2003 10:22 PM
keys
Aug 30, 2001 07:44 AM
