rod and main bearings
rod bearings are for the rods (for where the rods connect to the crank), and the main bearings are for the crank (where it is "connected" to the block if you will).
I need some clarification cause im looking to drop in a crank and i need bearings im told i need maid bearings n rod bearings but when i search the net no matter which i put in its the same part that comes up .. if i purchase the king main rod bearings is there another set of bearings i need to purchase ??
blinx9900
22
Jun 4, 2007 09:10 AM
