requesting info on jdm gsr cams
Old Mar 3, 2011 | 08:24 AM
93egboosted's Avatar
Default requesting info on jdm gsr cams
i have to degree my engine because my crank timing is off from the head and block being resurfaced, so i bought a set of adjustable cam gears. my engine builder is requesting the "tdc lift" in order to time my engine, ive searched only only came up with the lift and duration...
thanks
john
Old Mar 4, 2011 | 12:56 PM
Default Re: requesting info on jdm gsr cams
bump for some info
Old Mar 5, 2011 | 01:10 PM
john_crx's Avatar
B18C1
Intake
open: 10° before TDC
close: 40° after BDC
valve lift: 10.5 mm
Exhaust
open: 40° before BDC
close: 7° after TDC
valve lift: 9.4 mm
https://honda-tech.com/forums/acura-integra-6/jdm-gsr-cam-specs-578944/
Hope this helps
Old Mar 6, 2011 | 06:04 PM
Originally Posted by john_crx
B18C1
Intake
valve lift: 10.5 mm
Exhaust
close: 7° after TDC
valve lift: 9.4 mm
https://honda-tech.com/forums/showthread.php?t=578944
Hope this helps
thank you!
ZCHondaCRX91
Feb 10, 2011 07:36 AM
mhewitt
Sep 16, 2010 10:51 AM
raene
Jul 31, 2003 03:02 PM
infamousALLMTR
Feb 7, 2003 08:43 AM
civicboy95
Nov 18, 2001 02:51 PM
