Replacing fuel hard line
Old May 16, 2011 | 05:04 PM
nonvtecD's Avatar
Icon2 Replacing fuel hard line
I searched but couldn't find anything about this. I have a fuel line leak in my 89 hatch and I'm not sure what is involved in replacing the hard line that runs the length of the car. Please tell me I'm not going to have to remove the dash. I removed the rear seat, pulled the plastic cover over the lines as they run into the car and so on. It looks like I'm going to be removing a lot of plastic trim. Can anyone give insight if they have done this before?
Old May 16, 2011 | 05:31 PM
fcm's Avatar
fcm
Old Fart
Default Re: Replacing fuel hard line
What car do you have that has the gas line(s) running inside the car???
Old May 17, 2011 | 04:24 AM
nonvtecD's Avatar
89 Civic DX hatchback. The lines don't have any connections inside the car, and the leaky part is out back under the tank but there are hard lines that run through the floor, under the back seat, along the rocker panel, and then through the firewall.
Old May 17, 2011 | 05:56 AM
fcm's Avatar
fcm
Old Fart
I am going to have to look at an 89 DX, I can't find anything through Google that would help.
Can you see where the 3 lines go through the fire wall?
http://www.hondaautomotiveparts.com/...gry5=FUEL+PIPE 94
Old May 17, 2011 | 06:15 AM
slobalt77's Avatar
why not just cut the line before / after the leaky area, add the flare fittings and reconnect. be easier than replacing the entire length of line.
Old May 17, 2011 | 05:02 PM
nonvtecD's Avatar
FCM, excellent link, yes those three lines run up under the back seat, up the door sill, and under the dash. Thanks.
Slobalt, that is exactly what I did. It was much much easier.
Problem solved!
Edit: Also, while I'm hoping this doesn't happen again, the other two lines were plenty rust too. I might end up doing those sooner than later.
Sorcerer
Jan 21, 2017 11:13 AM
95accordian
Jul 19, 2016 08:35 AM
JDuval
Honda Civic (2001 - 2005)
Mar 20, 2013 01:06 PM
JRTegman987
Nov 7, 2006 07:19 PM
