removal of stock brake rotor
Old Oct 24, 2004 | 04:43 PM
Xxcivic99xX's Avatar
Default removal of stock brake rotor
I got my wheel off (pass side first) and I'm attempting to try to take out the bolt holding the calipers to the rotor piece... those are 17 mm right? I can't seem to put enough torque behnid it and where i can is a really awkward position. any advice?
Old Oct 24, 2004 | 04:54 PM
drdisco69's Avatar
Default Re: removal of stock brake rotor (Xxcivic99xX)
Yes it's a 17mm, and they are very tight. It's not hard to get enough force if you're using the right tools. What are you using? And try turning the wheel to one side to get more clearence.
Old Oct 24, 2004 | 04:58 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xxcivic99xX &raquo;</TD></TR><TR><TD CLASS="quote">I got my wheel off (pass side first) and I'm attempting to try to take out the bolt holding the calipers to the rotor piece... those are 17 mm right? I can't seem to put enough torque behnid it and where i can is a really awkward position. any advice? </TD></TR></TABLE>
Those are bitches, the first time you try to remove them. They are 17mm.
I have used a breaker bar (copper pipe or something beefier), or a spare jack to push the socket wrench. I assume you already shot them with liquid wrench or wd40?
A good solution would be an impact wrench. Small 12V ones that are meant for removing wheels are handy for things like this. Sometimes you need extensions to reach odd places like calipers though. I have one and I've used it for lots of random tight bolts.
250 ft-lb, $29.99
http://shop.store.yahoo.com/dy....html
Old Oct 24, 2004 | 06:29 PM
Default Re: removal of stock brake rotor (ccfries)
i think ima buy a breaker bar and use that. u all think a break bar will help me.
should i buy the 18 inch one or do i need a longer one?
Old Oct 24, 2004 | 06:37 PM
gunnis's Avatar
A breaker bar is a good thing to have. especially for breaking those real tough bolts.I.E axle nuts,caliper,control arm.
Any pipe that you can put over top of the ratchet will work fine. The more leverage the better as for length but keep it realistic, you don't need the thing 6 feet long.Good luck
Old Oct 24, 2004 | 07:19 PM
Chris F's Avatar
Default Re: removal of stock brake rotor (gunnis)
Yeah, buy 8 feet of copper pipe and a pipe cutter. Make your own to fit, as needed.
Old Oct 24, 2004 | 08:31 PM
eda6's Avatar
i use a 3/8 ratchet with 17mm socket. If i can't get it by hand I use 4lb hammer.
Turning the wheel helps when torquing it down.
Old Oct 25, 2004 | 08:05 AM
PrettyLude's Avatar
get a small 3/8 impact gun
wgbm92
Suspension & Brakes
Nov 9, 2010 07:02 AM
CRXSi90
Jul 24, 2007 04:18 PM
SupaMien
Oct 9, 2006 08:27 PM
sb
Aug 4, 2005 07:19 PM
1whitedc2
Jul 16, 2004 10:32 AM
