rebuilt motor,,water out the tailpipe
Old Jun 24, 2009 | 07:49 PM
xrated1's Avatar
Default rebuilt motor,,water out the tailpipe
When i start the car it starts to spit water litte small drops of it,,and when i back up spits a whole lot then,i dont see any drop of coolant anywhere and does not use any coolant or oil.Cylinders are dry when i look in the spark plug hole.Also i let the car sat on a half tank of gas for three months and used that gas to start up my rebuilt motor.
Any suggestions on why it does this.It has a brand new oem head gasket.
Old Jun 24, 2009 | 07:52 PM
StolenTeg's Avatar
Default Re: rebuilt motor,,water out the tailpipe
Condensation, if everything is running fine
Old Jun 24, 2009 | 07:56 PM
bakertime's Avatar
Sounds like that's just an after effect to letting it sit for that long and/or condensation. As long as it's not using coolant (or the 'water' doesn't smell like coolant) you should be ok. Might want to run some new gas through to see what it does.
Old Jun 24, 2009 | 08:08 PM
xrated1's Avatar
I DID I RAN IT EMPTY FIRST THEN FILLED IT UP WITH 91 PREMIUM,,,STILL HAVING IT BUT DOES NOT SMOKE OR ANYTHING AND WHEN I DRIVE IT AROUND AND PULL OVER AND CHECK IT BURNS DRY AFTER THAT,,ONLY HAPPENS IN THE MORNING START UPS.
Old Jun 24, 2009 | 08:14 PM
StolenTeg's Avatar
If it only happen in the morning than it condensation
Old Jun 24, 2009 | 11:56 PM
1992Si's Avatar
That's normal, all cars do that. Let us know if it happens after you start it after you've been driving it for a while and it has sat for a couple of hours.
Old Jun 25, 2009 | 09:36 AM
xrated1's Avatar
when driving around its dry,then i let it sit for a couple hours maybe 5 then it does again.
drive it around for 15min completley dry after that.
Old Jun 25, 2009 | 10:25 AM
bakertime's Avatar
You're 100% fine. It's just condensation like everyone is saying. When you run it, it gets hot enough to evaporate it...so when it sits for a little bit it just comes out as water. Here in PA it gets real humid in the summer and you see cars dripping water out the tailpipe quite frequently.
Old Jun 25, 2009 | 04:36 PM
xrated1's Avatar
thanks everyone for there input,,,i guess well see if it progress or not?Im still scared.
champLSinteg
Aug 28, 2009 08:42 PM
user 98292739
Sep 12, 2006 10:23 AM
turbotime
Sep 26, 2005 09:55 AM
Gumbey75
Feb 23, 2005 04:08 PM
Mr Miyagi
Nov 15, 2002 05:59 PM
