rear disk options which is better buy
i cant figure out which one to get
i have two complete rear ends available to me for use on my 93 cx hatch
1. RS complete rear end $140
or
2. GSR complete rear end with sway bar $250
what is the difference between the two and which one should i get for
my drum to disc conversion
also i have already converted my master cylinder and brake booster to GSR
and i have Civic EX front discs calipers hubs and steering knuckles
so the front is done and know i need to finish the rear
or
The rs swap will be of less work, same trailing arms and cables and rotors and calipers as the gsr.
If you get the gsr you have to drill/fabricate mounting brackets to use the gsr sway bar that comes with it, and also remove the rotor and dust shield to remove the abs unit underneath them.
For the hundred dollar difference, go with the rs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirty_d_cx »</TD></TR><TR><TD CLASS="quote">now i have another question which e-brake cable would i have to use or can i just use the stock</TD></TR></TABLE>
You need the ones from a 92-95 Si, the drums one won't work. It like $88 shipped for both from http://www.hondaautomotiveparts.com
Azxster
Oct 14, 2007 11:38 AM
dnt94civic
Feb 14, 2003 12:35 AM
