reading codes little problem
I believe you still reuse your existing diagnostic plug located in your engine bay on teh driverside wiring near your master cylinder/booster resting near the fender; all 88-91 civics/crxs have this plug btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxeflsturbo »</TD></TR><TR><TD CLASS="quote">Mine doesnt have it is there any other way</TD></TR></TABLE>
ok..did some research.
If your car is 88 or 89 or 88-89, there's a diagnostic plug where I mentioned that you jump in order to check the CEL codes (on the engine wire harness near the driver side fender).
If you have a 90-91 civic then the diagnostic plug is actually located under the passenger side dash, just like 92-00 civics/integra's. Jump the plug and your CEL light should start blinking..
Also, depending who actually makes your OBD0->OBD1 jumper harness, some of them have the diagnostic plug wiring integrated into the harness and you have to wire a togle switch to the 2 diagnostic wires so that you can flip the switch and check your mil codes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">
Also, depending who actually makes your OBD0->OBD1 jumper harness, some of them have the diagnostic plug wiring integrated into the harness and you have to wire a togle switch to the 2 diagnostic wires so that you can flip the switch and check your mil codes. </TD></TR></TABLE>
trust this guy, he knows his stuff.
i just finished up a how-to article on CEL Checking here:
http://technet.ff-squad.com/how-to/celcheck/
chinese acrobat
May 17, 2009 08:52 AM
