Racegas fuel concentrate
Hi I have a hi compression gsr 12.3:1 so I need to run 100oct or better. So has any one every ran race gas concentrate. Does it cause any detonation or anything and I was wounder if the racegas concentrate can be poured directly in the tank after filling up or do you need to mix it in a gas can first then pore it in
Good stuff, actually. you mix out with your fuel based upon a ratio (pre- calculated on a chart given). best to use 6 gallon cans to mix in as opposed ti pouring directly into the fuel tank
Not really a big deal since 50% ethanol gives 90% of the air-charge cooling that 98% ethanol does. It also enriches with a lower % mixture, so a lower ethanol mix somewhat fixes itself.
If you look at the tests Evo guys have posted, they get zero knock on their high-boost E85 tunes when they switch to E70.
